Like Tree404Likes
Yokomo YZ-4 SF
    Hide Wikipost
Old 02-06-2018, 06:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-4 SF
Last edit by: DG Designs
Old 12-09-2017, 04:42 PM
Default Yokomo YZ-4 SF
With the new car, comes a new thread for comments, questions, tricks, tips, setups, experimentations, constructive critique, pictures, videos, and news pertaining to the building, running, and maintaining of the Yokomo YZ-4 SF.
jpcopeland1 and Pekr.da.skurl like this.
archivist is offline
Old 12-09-2017, 05:45 PM
tommynash's Avatar
Anyone run into a problem with the rear battery post screw not being long enough?
tommynash is offline
Old 12-09-2017, 06:32 PM
Which screw: the 3x15 from the bottom, or the 3x10 set screw from the top?
Old 12-09-2017, 07:12 PM
i forgot to install it b4 i screwed the sidegauds to the chassis .. lol .
carpetburner is offline
Old 12-10-2017, 08:28 AM
tommynash's Avatar
I think that’s my problem haha thanks
Old 12-10-2017, 02:23 PM
Pekr.da.skurl's Avatar
Trader Rating: 12 (100%+)
I cant believe none you have your car together and presented us with a complete review yet
Pekr.da.skurl is offline
Old 12-10-2017, 07:04 PM
Not a complete review, but a few building notes.
- Usual Yokomo quality and fit. Needed very little (.25mm shim here and there) to be good.
- Shocks now come with screw on shafts. Farewell e-clips! Not the titanium coated ones but still!
- I had to change the shims for the diffs. With the manual setup, mine were bound in their casing and the drivetrain was not free. I had to remove the 0.05 mm on each side and move a 0.10 from one side to the other.
- Clearance between the top rear suspension link and the rear shock spring is minimal
- The new rear suspension hangers are very nice, and is quite a bit easier to understand.
Martin Paradis
rhodopsine is offline
Old 12-11-2017, 01:14 AM
Trader Rating: 166 (100%+)
Quick run update on mine. Went to my local track which is usually high bite clay, but with the heat and lack of humidity (SoCal Santa Ana Winds conditions), the track was pretty dry and had a layer of dust off the racing line which I drifted into a few more times then I normally would. First run out was pretty bad, car was very loose and had way too much steeering. Figured I would try running something closer to what Maifield was running at worlds since it seemed like It was close to those conditions. Made the changes, and the car was better with the tail end still being a bit too tail happy for a 4 wheel. Messed with shock oils, locations, but still ended up going with 2x1.7/32.5 middle hole arm, inner hole tower. if I tried to run any other configuration in the back, the shock became too stiff and springy. 1st day wasn't bad, mine you was only off my XB4 pace that has a center diff in it by .200 of a second consistent. I think another a brainstorming effort with me and a couple guys who do car setups I trust, and it will be just as good as the XB4 is right now. I'd like to add this as well, with the track being looser then normal, and the setup not being quite right, I did tag some pipe at very high speeds, and no breakage to speak of. Car is super durable.
lagcisco and Antimullet like this.
jpcopeland1 is offline
Old 12-11-2017, 01:17 AM
Taking notes and pics of each step of my build. Will post tomorrow when I finish it if anyone is interested?
stuffandthat is offline
Old 12-11-2017, 05:25 AM
Yes I'd love to see that. No hurry though. Take your time. Thanks in advance.
Swosh is offline
Old 12-11-2017, 10:16 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Hmm, I wouldnt mind some regular shafts if these work on the yz2's also ....
Cain is offline
Old 12-11-2017, 03:55 PM
Trader Rating: 65 (100%+)
Anymore drive reports?
Antimullet is offline
Old 12-11-2017, 09:03 PM
Motorman007's Avatar
Trader Rating: 89 (100%+)
What is the drive train
2.6?
2.5?
Add what other spurs will work on the buggy?
81 and 78.
Thank you.
Motorman007 is offline
Old 12-11-2017, 10:24 PM
my first 1/10 4wd buggy, so im not sure, is it ok that I can move whole slipper back and forth for about 1mm? No side play.
dabear is offline
Old 12-11-2017, 10:30 PM
tommynash's Avatar
Mine is like this as well following the manual
